Floor supply line...suggestions please
Discussion in 'Toilet Forum discussions' started by i-invest, Sep 12, 2008.
  1. i-invest
    i-invest New Member
    Sep 12, 2008
    Hi everyone...wondering if someone can suggest a toilet for me. I have a supply line coming through the floor, which limits size of the base I can install. I tried a Toto Drake, but no luck as the supply is too close and impedes the base. I have no desire to rip up the tile floors and fix the problem, so I'm looking for some advice. It appears I have to go with "older" technology as those toilets have a base a few inches forward from the wall, such as Am Standard Antiquity. Am Standard Cadet and Champion are too far back.
    I can't seem to identify a Toto that will work, which is unfortunate, as I do prefer a Toto. I did see some of the Eljers and Gerbers have the design that would work.
    Any advice would be greatly appreciated. Thanks in advance.
  2. Peanut9199
    Peanut9199 Customer Service Manager Plumbing Wholesale
    Apr 23, 2007
    Ontario, Canada
    Can you give us the dimensions from the wall to supply and center of the outlet to supply?
  4. i-invest
    i-invest New Member
    Sep 12, 2008
    Wall to supply 4.25" and center of outlet to supply 4", or slightly under 4. It's hard to measure. I assume when you say center of outlet, you mean the midpoint of the toilet, right?
  5. Peanut9199
    Apr 23, 2007
    Ontario, Canada
    4" from the center of the toilet (or outlet) i can't find any toilet with that small of dimensions.
  6. hj
    toilet
    New technology has little, if anything, to do with the toilet's appearance or size of the footprint. Some very cutesy toilets have poor technology and flush terribly.
  7. hj
    toilet
    New technology has little, if anything, to do with the toilet's appearance or size of the footprint. Some very cutesy toilets have poor technology and flush terribly. The 4" to the side of the outlet would be the hard part, (because few toilets are less than 9" wide meaning 4 1/2" just to get past them), but since many, if not most, do not come within 4" of the wall at the rear, especially since they are also rounded, you should have a large selection available.
Similar Threads: Floor supply
Toilet Forum discussions Replacement toilet with floor supply behind commode Monday at 9:53 AM
Toilet Forum discussions Is water supply from the floor a bad idea? May 17, 2016
Toilet Forum discussions Floor Water Supply - What Toilet Options Are Best? Nov 30, 2015
Toilet Forum discussions toilet water supply turnoff too close to floor Mar 29, 2012
Toilet Forum discussions Toilet water supply coming up from floor--can Carlyle fit? Jan 24, 2010
