Fleck valve questions
Discussion in 'Water Softener Forum, Questions and Answers' started by cruisecontrol49, Jan 10, 2013.
  1. cruisecontrol49
    cruisecontrol49 New Member
    Jan 10, 2013
    florida
    Good Day to all,
    I am trying to rehab a Fleck 5600 econo. I found a new main valve, and a brine valve, in some old plumbing yard sale boxes. I need to know if these valves will work as replacements for the original valves. The new valves look identical to the old one's except for the color. The original valves are green, the new main valve is gray and the new brine valve is black.
    thanks for your time and knowledge
  2. Tom Sawyer
    Tom Sawyer In the Trades
    Nov 29, 2010
    Maine
    Color alone won't tell you anything.
  4. Akpsdvan
    Akpsdvan In the Trades
    Dec 29, 2009
    Business owner/service and sales
    Alaska
    Photos of the current valve and some photos of that you found.
    Then we will have an idea as to what is going on.
    I know that there are green end plugs for the pistons of the 5600 and then there are black, white.... and I think a gray... so some photos would really help.
  5. Gary Slusser
    Retired
    ..... yeah it does, especially since he is talking about the main piston and brine piston.
  6. mialynette2003
    mialynette2003 Member
    Nov 24, 2010
    Owner of SWS Systems WWW.SWSSYSTEM.COM
    Ocala, Florida
    The green is a standard piston and the gray is a water saver piston IIRC. It will work fine.
  7. ditttohead
    Jan 9, 2012
    Ontario California
    Piston cap
    Grey = low water use, good for municipal or clean water supplies. Required in some areas for water efficiency
    White = standard, the most common in use. Good for well or municipal, uses more water during regeneration
    black = greensand or filter valve.
    Piston rod color has changed over theyears depending on the teflon manufacturer. Same goes for the brine valve color. The teflon coating color does not indicate anything. Be sure to carefully check the length of the brine valve, that design is used on many valves and the length can vary, it is very common for people to put in one that s too long or too short.
  8. cruisecontrol49
    Jan 10, 2013
    florida
    I tried to load some pics but wasn't having much luck. I finally got the phone number of a reputable pro...he's coming Monday with some other parts that I need for the control head.
    thanks for all your replies... I really appreciate your help.
Similar Threads: Fleck valve
Water Softener Forum, Questions and Answers Fleck 9100 SXT valve problems returned 60 days after replacing seals Feb 2, 2017
Water Softener Forum, Questions and Answers Rebuilding Fleck 2500 valve Jan 22, 2017
Water Softener Forum, Questions and Answers Fleck 7000, Valve body failed Aug 31, 2016
Water Softener Forum, Questions and Answers Corroded Fleck 9000 Valve Body Mar 27, 2016
Water Softener Forum, Questions and Answers Do I need a new brine valve on Fleck 5600? Oct 30, 2015
