Flange Ringer and concrete level question
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by gopokes65, May 28, 2011.
  1. gopokes65
    gopokes65 New Member
    May 20, 2011
    Denton, TX
    Posted here a couple weeks back about a rusted ringer on a closet toilet flange. I removed the metal ringer and chiseled out the bad concrete and then replaced it with hydraulic cement. My question is does it matter how much of a gap I leave between the new ringer and the concrete? I probably have about 1/2 inch gap between the new ringer and the new concrete. Will this matter? I am concerned that if I don't have this gap that I won't be able to install the new ringer as it is a tight fight with some of the surround granite tiles. Thanks for the input in advance.
    -Kyle
  2. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    I'm not sure what you are saying...
    Can you post a Pic please?
  4. gopokes65
    May 20, 2011
    Denton, TX
  5. hj
    If I had gone to that much trouble, I would have removed the entire old flange and installed a new one. From the picture it appears you should not have a problem, BUT it depends on what kind of flange you are going to use with what you have there.
  6. gopokes65
    May 20, 2011
    Denton, TX
    oatey moss bay replacement flange
  7. cwhyu2
    cwhyu2 Consultant
    Aug 11, 2007
    Consultant
    Cincinnati OH
  8. gopokes65
    May 20, 2011
    Denton, TX
    yes. But I just talked to another buddy who is a master plumber and he said go ahead and fill it up another half inch and then set the ring in the concrete.
  9. cwhyu2
    cwhyu2 Consultant
    Aug 11, 2007
    Consultant
    Cincinnati OH
    That would be OK but anchor the flange to the cement with some SS screws.
  10. Terry
    Aug 17, 2004
    If you just need to hold closet bolts, then I like these red rings. You can drill farther out.
    [​IMG]
  11. Redwood
    Dec 15, 2007
    Service Plumber
    I usually just put the flange on, then put the screws in place and pour in the cement...
    Done!
  12. hj
    I have had toilets which that red ring would NOT fit into the recess in the bottom. The two lugs where the closet bolts fit stick out too far, and the toilet sits on top of them.
  13. Redwood
    Dec 15, 2007
    Service Plumber
    I've had the same experience...
Similar Threads: Flange Ringer
Plumbing Forum, Professional & DIY Advice Toilet flange too high? Thursday at 7:18 PM
Plumbing Forum, Professional & DIY Advice Replace Toilet Flange? Feb 6, 2017
Plumbing Forum, Professional & DIY Advice Cast iron riser to toilet flange Feb 5, 2017
Plumbing Forum, Professional & DIY Advice Help with toilet flange Jan 21, 2017
Plumbing Forum, Professional & DIY Advice Closet flange questions Jan 10, 2017
