Fixing a Kohler Ingenium
lidsky
Hi,
I have a Kohler with the Ingenium flush system. It has the problem where the water continues to run after the tank is full. Also, it will spontaneously start running if some other water in the house turns on. If I reach in, the lever is at the top and if I just push it up a bit, it shuts off. This tells me either the lever is stuck right at the top or the water level is a bit high so it goes through the overflow as opposed to shutting off.
I can't figure out how to adjust the water level, or the valve, so it isn't on the edge like this. Anybody have any pointers, corrections on my assumptions, or a pointer to a "how-to" guide.
I couldn't find anything useful on Kohler's website.
Thanks in advance,
David
