sajesak
i bought a 30 inch fire door with the adjustable metal flange..I have plaster walls and when I took off the trim some of the plaster fell off.
The rough opening is 33 inches..when I put the door in..I have 3 inches of gap. Was I supposed to get. 32 inch door?
If I stick with this door I will have to add at least one two by four.
Does the flange go on top of the plaster? In which case I need to do some repairs. Or does it go on the stud and then you plaster or Sheetrock over?
If the flange goes over the Sheetrock or plaster then would the trim stick out a little? Also would it be hard to nail in because you can only do it where there are certain openings in the flange?
