Fire door with flange
sajesak
United States
i bought a 30 inch fire door with the adjustable metal flange..I have plaster walls and when I took off the trim some of the plaster fell off.
The rough opening is 33 inches..when I put the door in..I have 3 inches of gap. Was I supposed to get. 32 inch door?
If I stick with this door I will have to add at least one two by four.
Does the flange go on top of the plaster? In which case I need to do some repairs. Or does it go on the stud and then you plaster or Sheetrock over?
If the flange goes over the Sheetrock or plaster then would the trim stick out a little? Also would it be hard to nail in because you can only do it where there are certain openings in the flange?
sajesak
United States
If the flange goes over the Sheetrock or plaster then would the trim stick out a little Branddörrar? Also would it be hard to nail in because you can only do it where there are certain openings in the flange?
thanks for any help
You might not be tal;king about a door but an access panel a 30x80 door wont fit with a 3 inch gap in a 33 opening . but in any case if you have the door it should be evedent along with instructions on how to install
