Finding short in Cat5e cable
Jriker1
Illinois
I am in the process of cleaning up my cables and as part of it testing all connections. One cat5e wire that snakes thru the walls and I can NOT replace as it's not going to pull around the bends, is showing what seems like a short according to my simple tester. It goes thru wire 1, 2, 3, 4, and then 5 and 6 light up, then when it would be showing 6 5 and 6 flicker and stay lit again, then goes to 7 and 8. This happens with the connectors on either end not plugged into anything. As a matter of fact if I connect the battery powered end of the tester on one end, and don't connect the other end it still does this. I replaced one side of the connector but not the other. Any recommendation on what to do? I have heard there are devices that can literally tell you how far along the cable the short is, but not sure if I would have access to one at the local home depot or what. Thoughts on how to troubleshoot this? Or a different way to wire up the connection to get the most use out of the cable as is?
Thanks.
JR
Identify which wires are shorted. Measure the resistance between the shorted wires from each end. The resistance will be lower near the short.
http://www.incentre.net/tech-support/other-support/ethernet-cable-color-coding-diagram/ says
You can also see that both the blue and brown wire pairs on pins 4, 5, 7, and 8 are not used in either standard. What you may not realize is that, these same pins 4, 5, 7, and 8 are not used or required in 100BASE-TX as well.
An RJ45 Ethernet Connector Breakout Board can make taking readings easier. Probing with alligator clips grabbing small sewing needles used as probes is awkward.
Bluebinky
Des Moines, WA
Like Reach4 said, 10/100/1000 baseT only use two pairs -- just use the good ones.
Gigabit ethernet use all four, I think. Sorry, I'm too lazy to look up the RFC.
Ankhseeker
San Pablo, California
They usually reserve the other pairs for PoE or telephone. You could always change/rewire the jacks for the good pair of wires, but the integrity is already compromised and might create a bottle neck if you push too much data through it.
