final drawing for plumbing
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by snottyvar, Feb 28, 2012.
  1. snottyvar
    snottyvar New Member
    Feb 25, 2012
    Newfoundland
    Hi again. I think I have learned. Please take a quick look at the drawing. I have decided to use and air admitance valve on my kitchen island as it is right there under the sink and easy to replace when the time comes. Also assume slopes of 1/4 inch per foot. I did my best drawing but it was hard to reflect the slope. San Tees will be uses on all trap arms. All pipes are 3 inch down to 2 inch for vents and the kitchen, tub and shower drains. The basins will be 1 1/2 inch. Thanks again
  2. Tom Sawyer
    Tom Sawyer In the Trades
    Nov 29, 2010
    Maine
    Yes, it's fine
  4. snottyvar
    Feb 25, 2012
    Newfoundland
    Thanks so much for your time. Cheers
  5. hj
    IT will work but it may look more complicated than it has to be, depending on the floor plans
  6. snottyvar
    Feb 25, 2012
    Newfoundland
    At this point running all those pipes is easier than changing the plan. My brain hurts. I'm just happy you guys think it's alright. It is an open concept house with a supported ridge. I can put the bathroom walls anywhere I want. I was waiting to finalize the plumbing before I even built the walls. Cheers
  7. hj
    quote; At this point running all those pipes is easier than changing the plan.
    IN that case you may be a masochist, especially if the wall locations are not definite.
  8. Terry
    Aug 17, 2004
    It's about whether it works; the basic concept. To me, it looks like you "get it".
  9. hj
    See, I might use a single stack placed at, or near, the lavatory. Downstairs the toilet would connect to a Wisconsin/cottage tee angled towards its location. It would be connected to a tee in the mair riser. The sink would be a tee into the toilet vent and the tub would connect to the toilet's tee side inlet. The upstairs would be the same with the downstairs vent tied in 42" above the floor. But, this would depend on HOW the house is constructed and the placement of the two bathrooms.
  10. snottyvar
    Feb 25, 2012
    Newfoundland
    I thought all plumbers were masochists. Now you've given me a bunch more stuff to look up and figure out. Cheers
  11. hj
    plumbers
    When it comes to apprentices, we become sadists. They are masochists for putting up with it.
Similar Threads: final drawing
Plumbing Forum, Professional & DIY Advice Island/Peninsula Loop Vent - Final Check Jan 5, 2017
Plumbing Forum, Professional & DIY Advice Finally Replacing My Late 90s No Flow Gerbers And Now Plumbing Questions Have Come Up Sep 20, 2016
Plumbing Forum, Professional & DIY Advice 1/4 turn twist not doable on final PVC joint--best solution? Aug 18, 2016
Plumbing Forum, Professional & DIY Advice Well Jet Pump - Pressure plummets on use and finally recovers Dec 21, 2015
Plumbing Forum, Professional & DIY Advice 1 final vent termination size? Jun 20, 2011
