donmecca999
I recently installed a banded fernco coupler to connect the existing ABS drain to some new PVC pipe. The guy at home depot said to just tighten it down and I wouldn't have any problems with leaks. I got to reading online and see that a 2in Fernco should be tightened to 60lbs, however when I installed this I simply hand tightened the connector tight as I could get by hand.
Question is, will I have any future problems with this fitting because I didn't torque it to 60lbs? I did run some water through the drain, no signs of anything leaking. This fitting is now buried in the floor and would be a major pain to open up again to tighten further.
Thank You
Thank You
