AVR
hey all, have an issue that a plumber could not solve.
I'm on a well in North Carolina. moved into house 6 months ago. noticed some sputtering when 1st moved in but it went away for 6 months. also have tankless hot water heater, and pressure tank. no softener, and only an inline whole house filter sump style.
Now it's sputtering again, some days worse than others.
We had a whole house filter - sump style when we moved in, and we changed filters a few times. had a new filter housing installed and they cleaned up the previous job that was not done properly. faucets were sputtering before they swapped this out FYI.
i see bubbles when the pump kicks on in the clear housing of the whole house filter. had a plumber out today, they claimed they checked the well and ruled out the well.. they were stumped
bladder tank seems okay, knock on sides sounds good has air in top.. psi on the tank measured what the pressure gauge shows.. have a check valve before the pressure tank.
have a slow leak at 1 shower head that drips.. just a heads up, was told that wouldnt cause sputtering.
plumber is stumped? anyone have any suggestions? it had been problem free for last 6 months, no sputtering at faucets, not all of a sudden its back..
