faucet set in deep well
Discussion in 'Remodel Forum & Blog' started by celticgarden, Jun 3, 2005.
  1. celticgarden
    celticgarden New Member
    Jun 3, 2005
    Scenario: bathroom vanity sink from 50's. Trying to remove faucet. Cannot access or remove the nut that secures the faucet against the porcelin from underneath. Basin wrench can't turn because the "well" is so narrow. Copper connections from faucet spout to hot/cold turnoffs make it like one piece. How did they ever get it in there and is there no way to get it out? I have progressed to the point where the hot/cold valves and connections would just drop out underneath IF they could be disconnected from the faucet part but then I would still face the problem of lossening the nut that secures the faucet. The faucet can't be budged from the top....ack
  2. Mike Swearingen
    Mike Swearingen New Member
    Jan 12, 2005
    Independent Real Estate Broker
    On Albemarle Sound In Northeastern NC
    Wear a heavy work glove and use a hacksaw blade to cut the nut under the sink by hand. Once cut, tap it off with a hammer and chisel or large flathead screwdriver to remove it.
    Good Luck!
Similar Threads: faucet deep
Remodel Forum & Blog What to look for in a lav faucet when PSI low Jun 27, 2016
Remodel Forum & Blog Main shutoff and outside faucet pressure fix Jun 21, 2015
Remodel Forum & Blog Help with Delta 200 Wall Faucet Jun 13, 2015
Remodel Forum & Blog Kitchen faucet with pull out opinions? May 29, 2015
Remodel Forum & Blog Grohe faucet help -- British thread 'adapter' Sep 25, 2014
