ENT Bushings - Are they required?
Discussion in 'Electrical Forum discussion & Blog' started by seaneys, Aug 11, 2007.
  1. seaneys
    seaneys New Member
    May 8, 2007
    Chicago Suburbs
    Hello,
    I'm in an area that requires conduit. I've always used plastic insulating bushings on all threaded fittings (inside of boxes). Over the past few weeks I have noticed that both of my big box stores have stopped carrying them.
    I paniced a little, then decided to dig through the 2005 NEC. I do not see that they are required.
    Are these things really required? Do I really need them?
    Halex P/N 75205B is a sample in case you do not know what I am referring to.
    Thanks,
    Steve
  2. Bob NH
    Bob NH In the Trades
    Oct 20, 2005
    New Hampshire
    300.4(F) requires that ungrounded conductors #4 AWG and larger " . . shall be protected by a substantial fitting providing a smoothly rounded insulating surface, unless the conductors are separated from the fitting or raceway by substantial insulating material that is securely fastened in place."
  4. seaneys
    seaneys New Member
    May 8, 2007
    Chicago Suburbs
    Ahhh.. Just to make sure I am clear.
    So I am using the typical application of 6 or 7 pieces of 12ga wire in 1/2" ENT the bushings are technically not needed. If I were pulling a 4 ga or larger wire (subpanel, etc), however, I would need to use them.
    Thanks,
    Steve
  5. Bob NH
    Oct 20, 2005
    New Hampshire
    That's correct. For example, you can run as many #12 as you can get through a 1/2" metal offset nipple because even the fill requirements don't apply.
Similar Threads: Bushings required
Electrical Forum discussion & Blog Why is a ground wire required from a generator? Dec 20, 2009
Electrical Forum discussion & Blog Laundry in bathroom, GFI required? Dec 25, 2007
