1/4 turn shut off required by code for residential sink hot water supply???
Bmusgrove
Cedar Hill, Texas
Is a 1/4 turn shutoff required by code for the hot water line to household sinks? North Central Texas area.
Background - Recently experienced a valve bonnet failure on a toilet water supply stop, causing a few thousand dollars of damage. After visually inspecting several other stop valves in the house. I decided to go ahead and replace all of the stop valves in the house. Yes, it is overkill, but the peace of mind is worth it. A couple of the "big box" plumbing shops I have received estimates from have stated that a 1/4 turn stop valve is REQUIRED by either code (multi turn unsafe in hot water situations) or the manufacturer (multiturn not suited for hot water applications). Unsurprisingly the cost is a tad (;)) higher
So.... I understand where a 1/4 turn could be advantageous, but REQUIRED for residential? Unsuitable? Right off the hot water heater yes, but for intermittent use at the sink?
Also. While I do not mind 1/4 turn (might even prefer them), I do not like the smaller handle style of the 1/4 turn valves on the BrassCraft (or BC generic's) they have shown me. I cannot grip them. What is a reputable brand with larger handles, similar to the large oval handles on Brass Craft multiturn? Something I can ask a smaller local plumber to use when I find a shop I like?
Use whatever you like 1/4 turn not required. some really think highly of Dahl angle stops they aren't any prettier than a bBass Craft but most seem to think better quality. they seem good to me I've installed a few dozen I don't like the handle appearance either. I'd go 1/4 turn Brass Craft or Dahl on my own home.
BTW I don't think replacing is overkill
Tuttles Revenge
Brasscraft makes a 1/4 turn with a cross handle. XKTCR19X NS
Tuttles Revenge
When the lead free mandate went into effect and manufactures had dug in their heels, our plumbing suppliers switched over to the angle stop shown below with the plastic ball. This is the type typically found in box stores. The metal ball style is more durable. Its easily identified by its handle shape... if you end up looking further at brasscraft.
Metal ball
Plastic ball
Didn't realize plastic handle plastic ball identifies it. those cross handle brass craft look nice for a pedestal trying for a older look
Tuttles Revenge
Yeah.. We had a customer supply their own stops once and that is what they provided. I showed them and they decided to use our stops after pointing out the difference. Then when I saw that was the only stop available at the time at our wholesaler, I knew why we were getting stuck with those valves.
After the fiascos we had with the plastic valves in the Manabloc system, I just won't use them if I can
