Electrical Box in 2x6 T&G ceiling
Discussion in 'Electrical Forum discussion & Blog' started by Count Fred, Mar 12, 2008.
  1. Count Fred
    Count Fred New Member
    Mar 12, 2008
    I have a 2x6 car decking ceiling with a 2x4 cavity above through which to run electrical and plumbing. I'm puzzled by the best type of box to use to mount light fixtures in the room below. Obviously I'm going to want to cut into the ceiling to get the box flush with the bottom surface of the T&G, but I will then need to fasten the box somewhere in the ceiling. Most boxes only want to account for 1/2 wallboard, and I effectively have 1.5" of material to deal with.
    Is my best bet going to be a ceiling fan type box, with a 2x4 between the cavity joists?
    Thoughts,
    JFS III
  2. Mikey
    Nov 8, 2005
    Consumer
    Hansville, Washington
    Most light fixtures expect a 4" "ceiling box" which is a kind of rounded-off square box (also called an "octagon box"):
    I always mount them as you described -- on a 2x4 in the joist cavity. A similar box is available for about 3x the price called a "ceiling/chandelier box" and comes with hardware for mounting fixtures like fans or (!) chandeliers, but the weight of your fixtures will determine which you need.
    Get the kind of box that has knockouts in the bottom (shown), since you won't be able to bring the cables in to the side of the box. Drill or saw a hole in the 2x4 to match up with the bushing in the box and pass the cable through the hole.
    They make these boxes with a mounting tab attached, which would eliminate the requirement for the 2x4 (just mount it to the side of a joist), but I don't like them -- you're limited in where you can mount the box, and I wouldn't trust them with any weight:
    Do you have access to the space above the ceiling?
  4. frenchie
    frenchie Jack of all trades
    Dec 30, 2006
    Caretaker
    They also make them with a hanger bars, like in this pic. The steel version (couldn't find a pic) will have 5 K/O's on the bottom, use the center one to attach to the hanger bar, leaves you 4 you can use.
    (edit: "can't find a pic" - doh! - the top picture in Mikey's post is the kind of box I mean)
  5. Lakee911
    Lakee911 I&C Engineer (mostly WWTP)
    Aug 23, 2005
    Columbus, OH
    Why not use a remodel box and screw through the edge of the box in to the 2x6. I know screws through side of box may not be code compliant, but it would work. Other option could be a remodel box with longer screws for the tabs, or possibly with a box extension if they make an octogon extension.
    Jason
  6. jadnashua
    I think you can use screws to attach the box, but can't have screws running through the box with exposed threads that could cut the insulation.
  7. Chris75
    Chris75 Electrician
    Aug 12, 2007
    Electrician
    Litchfield, CT
    Thats why they make these...
    http://www.contractor-books.com/SmartBox.htm
Similar Threads: Electrical ceiling
Electrical Forum discussion & Blog Hidden electrical boxes in ceiling. Nov 19, 2008
Electrical Forum discussion & Blog Is this plumbing or electrical code? Today at 4:57 AM
Electrical Forum discussion & Blog Electrical Inquiry Mar 18, 2017
Electrical Forum discussion & Blog Electrical shorts Mar 17, 2017
Electrical Forum discussion & Blog Electrical supply to barn and garage Feb 9, 2017
