Hello, I’m hoping you guys can help an novice out with what I need for my DWV before I pour my shop floor. The plumber who I had originally lined up to do the work has basically told me he’s not going to get to it. I’m frantically trying to learn as much as possible to get this installed myself so I can move forward as this is supposed to be our home for the winter. There are no permits or inspections required in my area in Western Montana.
Behind my washer machine is where I would like to run my main vent up and have everything attach to there. So it’s not visible in my loft.
I’m not sure what’s best for venting my shower and toilet, I’ve seen where the vent is in between the two at an angle to the wall before going vertical.
Can both sinks on opposite walls share the same drain and vent?
my septic tank is approx 125’ away from the shop. I will need 2 45° to get out off the shops knock out as well as 2 45° to get to the inlet.
Yes, I know I should probably leave this to a professional but everyone else I’ve called is sold out till next year or won’t return my calls. My wife will not be happy with me if she has to live in a camper for the winter..
Thank you!
Thank you!
