DWV configuration analysis
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by accidentalplumber, Dec 19, 2012.
  1. accidentalplumber
    accidentalplumber New Member
    Dec 19, 2012
    Issaquah,Wa
    Hello All
    Question for the pro's will this config work properly?
    Thank you.
    John
  2. Terry
    Aug 17, 2004
    The photo and the picture don't seem to match.
    To me, a Washington State plumber, it's not right for inspection.
    The toilet needs to be vented within six feet. A kitchen sink can't be used to vent it.
    A lav can, if you are running 2" for the lav and vent, within six feet. Once other waste is coming down the line, it's no longer a vent. I say that noticing that the lav is on the other side of a 3" main waste line.
    If that 3" near the toilet is truly a vent, you could throw a santee off the vertical and trap over with a 90.
    If there is plumbing coming down the stack, then that wouldn't work. Without seeing a drawing going through the roof, it's a bit hard knowing what the plan is.
  4. accidentalplumber
    Dec 19, 2012
    Issaquah,Wa
    Hello Terry
    Thank you for the reply. I will try to make this less confusing. The vertical closest to the camera, just over the level will be the vent stack and will only have a tub and washer empty into it. It will also vent the basin. As far as the future toilet goes it will have its own vent when the time comes. Hope you are not totally confused now.
  5. accidentalplumber
    Dec 19, 2012
    Issaquah,Wa
Similar Threads: configuration analysis
Plumbing Forum, Professional & DIY Advice Storage Tank and Pressure booster with tank configuration Friday at 7:28 PM
Plumbing Forum, Professional & DIY Advice Help with new disposal trap configuration Oct 2, 2016
Plumbing Forum, Professional & DIY Advice Toilet base configuration for carpet Mar 10, 2016
Plumbing Forum, Professional & DIY Advice Drain pipe configuration question Jan 22, 2016
Plumbing Forum, Professional & DIY Advice Kitchen sink pipes configuration Nov 21, 2015
