DUROCK Cement Board for Exterior Walls
Discussion in 'Remodel Forum & Blog' started by MAD King, Dec 25, 2013.
  1. MAD King
    MAD King New Member
    Mar 24, 2013
    Nashville, TN
    Hello,
    can I use the cement boards for the exterior walls?
    I would like to replace the vinyl siding and the plywood underneath with the cement board.
    I read a little bit that it is possible, but not on how it is done right.
    Anyone with good advices?
    Thank you
  2. jadnashua
    At least some of the cbu manufacturers (James Hardie for one) make cement based exterior siding...I'm not sure about Durock. On some, you can get it prepainted, or in a primer. Also comes in various styles and panel sizes. Over the years, some of them have had issues, but much of that falls back to not following the instructions to the letter (critical on this type of install).
  4. MAD King
    MAD King New Member
    Mar 24, 2013
    Nashville, TN
    Thank you for your reply.
    I know about the cement sidings, but I do not like the look of it.
    That's why I would like to have the cement board and on top some stucco.
  5. jadnashua
    I do not think any of the cbu boards are suitable as a structural panel (i.e., say in place of plywood for the cladding)...they are only a compatibility layer for mortar based materials. For wind load, earthquakes, and similar loading, the cbu cannot be used alone - ply, or a similarly rated material must be there to prevent racking and as a resilient panel that holds things together. Cbu would crumble around the fasteners if it were required to be a load bearing panel under those circumstances and then not provide the structural strength required.
  6. MAD King
    MAD King New Member
    Mar 24, 2013
    Nashville, TN
    But aren't the panels made from the same material?
  7. johnfrwhipple
    johnfrwhipple BATHROOM DESIGN & BUILD for both Canada & the US
    Jul 20, 2009
    Design Work World Wide: Bathrooms Vancouver Area
    North Vancouver, BC
    Durock from what little I have seen of it is a crappy board.
    Wonderboard Panels look much better.
    Hardi Backer Panels not approved for outdoors.
    You will want drainage, a rain screen, a scratch coat, a brown coat and a top coat.
  8. MAD King
    MAD King New Member
    Mar 24, 2013
    Nashville, TN
  9. Dana
    Dana In the trades
    Jan 14, 2009
    01609
    Not all fiber cement backer-boards are rated for exterior use- many will fall apart from freeze/thaw cycles in short years in a Nashville TN climate.
    If you are going for stucco, you need at least a 1/4" ventilation gap (3/4" is better) between the stucco and any sheathing or the moisture drives during the summer will rot your finish wall. If wood sheathing, you'll need a ~0.6-2 perm vapor retarder (double-layered #15 felt is the classic) on the vent-gap side of the sheathing.
  10. johnfrwhipple
    Jul 20, 2009
    North Vancouver, BC
    I worked with both boards this month. Love Wonder Board - hate Durock.
    Found the Durock, dry, brittle and very weak at the surface layer.
    Don't think a cement backer board is your answer.
    Look up Rain Screens and go at the process with a more traditional install.
    Stucc is a funny beast. Lots of variations you can try.
    Do you have a local stucco supply yard? They have many products designed to make life easier for you.
  11. jadnashua
    Fiber cement siding is applied over the structural wall sheathing, it is for appearance and waterproofing, not structural purposes. While an interior wall may add some structural strength, and cbu may be used there, just like drywall, it is not structural from the external viewpoint.
Similar Threads: DUROCK Cement
Remodel Forum & Blog Screws in Durock...tool late? Aug 5, 2010
Remodel Forum & Blog Window replacement plus house settling Nov 20, 2016
Remodel Forum & Blog Smoke/CO detector placement in a bedroom Jan 18, 2016
Remodel Forum & Blog Home run Polybutylene replacement Jun 2, 2015
Remodel Forum & Blog Replacement water service questions: Mar 30, 2015
