drip irrigation with 1/2" copper pipe
Discussion in 'Irrigation / Sprinkler Forum' started by rati, Mar 28, 2009.
  1. rati
    rati New Member
    Mar 28, 2009
    I want to install a drip irrigation system, but the available pipes are only 1/2" copper. (Tapping into the main line would involve ripping a new driveway, so it's not an option.) Will the system work if I use an adapter between the 1/2" and a 3/4" control valve? I have fairly high water pressure--85 api.
    Thanks.
  2. chris8796
    chris8796 New Member
    Jan 8, 2005
    Illinois
    If you stick to drip and limit your branches to ~ 4g/min you should be ok. You probably can get higher flow rates in your 1/2" pipe, but its not recommended to exceed flow velocities of 7 ft/sec (water hammer and other problems).
  4. rati
    rati New Member
    Mar 28, 2009
    Thanks! I'm planning on using a regulator to step down the water pressure to a level that will work with a drip system. Will this also reduce the flow velocity to a level that will avoid water hammer or other problems you mentioned?
Similar Threads: drip irrigation
Irrigation / Sprinkler Forum Application of Drip irrigation pipe Oct 27, 2016
Irrigation / Sprinkler Forum What is Drip Irrigation? Jul 13, 2016
Irrigation / Sprinkler Forum PVC Drip Irrigation System for your garden Jul 8, 2016
Irrigation / Sprinkler Forum Drip Irrigation system often leaks at barb connections to mainline Jun 22, 2016
Irrigation / Sprinkler Forum drip system to standard irrigation system Oct 19, 2014
