Craigpump
15 feet of water is about 22 gallons
Rig up about a 3/4 HP, 10 GPM submersible to run on a generator. Drop it down on a piece of 1" poly pipe. Then you can clean out and test the well to see what you have. Even if you have to valve it down to 1 GPM to keep it running, that is 1440 gallons per day to pump to the house.
Call me cheap, but you can probably find a guy with a hoist truck with a sandline and bailer to come in and bail the well for a few hundred bucks. Bailing the well will clean the crap out of it and prove the yield of the well without having to spend a bunch of money for a pump, pipe and wire along with a generator.
He doubted the location because it is at the bottom of a hill.
Was that a driller or some water well witch?
Everyone knows Jack and Jill went up the hill to fetch a pail of water.
If there is no water coming from the hill, what feeds the spring?
