Drake or Ultramax?
Discussion in 'Toilet Forum discussions' started by TMinNC, Jul 7, 2008.
  1. TMinNC
    TMinNC New Member
    Jul 7, 2008
    In a fit of frustration I ordered a Drake to replace a standard builder supplied toilet in our downstairs powder room. My plan was to replace it and depending how that went to replace the others in the house.
    All the talk about leaking Drake's have me wondering if I should have gone w/the Ultramax. I've read the install notes here and will be sure follow them to a T.
    But, from a performance standpoint is there any difference in these two models?
    Thanks,
    Tom
  2. jadnashua
    On a two-piece toilet, there are a few simple things that should be done during installation:
    - the area around where the bolts go to hold the tank should be smoothed over; takes all of 10-seconds per hole. This allows the rubber washer to make a good seal*
    - the nut that holds the flapper seat should be checked to verify it is tight, again, takes all of a few seconds.*
    - make sure that the nut that holds the filler valve in place is tight
    If you do that, and any conscientious installer should, you don't have problems.
    * Two-piece only
  4. TMinNC
    TMinNC New Member
    Jul 7, 2008
    Jim,
    Thanks for the tips. I did see these as part of the install process named here online and will make sure to follow them. I think the tip about sanding the area where the rubber washers sit is a key one.
    Any performance difference between the two models I mentioned? I don't mind the 2 piece look just looking for a price/performance match.
  5. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    The sanding is a precautionary step that while perhaps not necessary, is a very good and easy thing to do. I just gives added insurance that the tank bolts won't leak. Take your time tightening them. Rock the tank while pressing down and alternate sides often while tightening. The tank may not want to go tight against the bowl, and that's OK. Don't over tighten the nuts, just nice and snug.
  6. SamC
    SamC Member
    Apr 12, 2007
    Georgia
    Actually, according to the latest MaP report, the Drake performs better than the Ultramax at flushing bulk media, flushing 900 grams as opposed to 700 grams, because the level of the water in the tank is higher, providing a higher head pressure. But since the average human stoole is less than 350 grams, anything over that is fine. You might consider the EcoDrake or EcoUltramax, which use only 1.28 gallons of water, and still flush 600 grams and 500 grams respectively.
  7. TMinNC
    TMinNC New Member
    Jul 7, 2008
    Sam,
    Thanks for the info. I have a drake enroute and hope to install it thiseekend. If flushing goes well I will put a toilet bag in the tank to reduce the water usage. Its a small plastic bag that you fill with salt water to displace a given amount of volume. It can turn a 1.6 into a 1.28 tank.
  8. Terry
    Aug 17, 2004
    With the Drake, you can order it with either the 1.6 tank or the 1.28 tank.
    They cost the same.
  9. TMinNC
    TMinNC New Member
    Jul 7, 2008
    I kind of like the idea of having an "extra gear" w/the 1.6. If all goes well I might go w/the 1.28 for the other 3.
    Terry - any thoughts on expanding your shipping to the East Coast?
  10. TMinNC
    TMinNC New Member
    Jul 7, 2008
    Got the Drake Installed
    Looks good so far. Kids will be home all day tomorrow - so it will be a good test.
  11. RCraig
    RCraig Member
    Nov 20, 2004
    New Hampshire
    Impressive
    Hope the kids and you have a good day together and hope the test works! R
  12. TMinNC
    TMinNC New Member
    Jul 7, 2008
    Everthing is working well. Its been about 1 week and no issues at all.
  13. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Whooda Thunk! I Woulda!
    Another Happy Toto Owner!
  14. RCraig
    RCraig Member
    Nov 20, 2004
    New Hampshire
    very good
    Hope I have the same good news when my Drake gets installed next Wed. R
  15. Redwood
    Dec 15, 2007
    Service Plumber
    You will!:cool:
  16. RCraig
    RCraig Member
    Nov 20, 2004
    New Hampshire
    sweat catcher
    I am planning to put on the sweat-catcher drip tray even though it is an insulated tank-Drake, just in case. R
  17. jadnashua
    Putting anything in the tank of the Toto may compromise the flush. Essentially none of the newer toilets empty the tank when you flush. Adding that bag in there could work if it was an older style toilet that did empty the tank, but may just cause the toilet to reduce the water used in the flush so it won't perform properly.
    As I understand it, the way the Eco versions of Toto's toilets save is more on limiting the bowl overflow rather than using less to dump into the bowl while the flapper is opened.
    If you do try it, let us know. My guess is it might impact the flushing operation.
  18. RCraig
    RCraig Member
    Nov 20, 2004
    New Hampshire
    outside back
    This will hang outside the tank, underneath it. It has sponges in it, catches the toilet sweat on the outside. Not very efficient but I have been decimated by toilet sweat so I am overworried about the sweating. Ruth
  19. Gary Swart
    Sep 1, 2004
    Yakima WA
    Don't make it a permanent mount. I seriously doubt that you will have any sweating for all of the reasons previously discussed and this attachment thing will be totally unnecessary. Enjoy your new Toto.
  20. RCraig
    RCraig Member
    Nov 20, 2004
    New Hampshire
    PS rain finally stopped over here. But it is supposed to rain again tomorrow. R
Similar Threads: Drake Ultramax
Toilet Forum discussions Help decided Drake ver1 Vs Ultramax 2 Jan 22, 2017
Toilet Forum discussions Deciding between Toto Drake II, Toto Eco Drake, Toto Ultramax or Kohler Cimarron Jan 17, 2016
Toilet Forum discussions Any thoughts on the 1.0 GPF TOTO toilets (Drake II and Ultramax II)? Jan 20, 2015
Toilet Forum discussions Terry: I need to buy 3 replacement toilets, which Toto? Drake,Ultramax, Ultramax II? Jan 4, 2015
Toilet Forum discussions New TOTO Connelly and ECO Drake and Ultramax II 1G Sep 3, 2013
