Double Fixture cross Usage with an Immediate horizontal turn
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by KenLewie, Jan 23, 2014.
  1. KenLewie
    KenLewie New Member
    Jan 23, 2014
    Minnesota
    Hello,
    I'm a G.C. doing a kitchen and bath remodel in a very old home. My plumber (who I have not worked with before) tells me that this will be ok. I know he is gonna have to ask the inspector anyway but I want to start framing for the changes ASAP. I originally suggested leaving out the jog and making the pipe look like a post when it goes by the kitchen island. The homeowner would rather not have the fake post with a plumbing pipe in it next to an eating area. So the plumber is suggesting this jog around the island where it can be buried into a wall. What say you all? Thanks for you time and consideration.
  2. Terry
    Aug 17, 2004
    The jog is fine.
    If you ever replace those toilets, and they have 3" flush valves in the tank, the water will skip across the fixture fitting and push a bit of water out of the opposing bowl.
    It's not too bad. At least you don't have a double santee there.
  4. KenLewie
    KenLewie New Member
    Jan 23, 2014
    Minnesota
    Thanks for the feedback Terry!!! Great site you have hear. I will keep the 3" flush valve in mind. Would it make much difference to use a combo double Y with 1/8 bends rather than the Double fixture fitting. I believe there is room since both toilets are 18" from the wall to their sides?
Similar Threads: Double Fixture
Plumbing Forum, Professional & DIY Advice Double fixture fitting - sink next to washing machine standpipe Jan 19, 2014
Plumbing Forum, Professional & DIY Advice 3 inch Double Fixture Fitting with 2 inch reducers? Nov 23, 2013
Plumbing Forum, Professional & DIY Advice Converting to double sink-drain pipe too close to stud for double fixture fitting. Mar 10, 2012
Plumbing Forum, Professional & DIY Advice Back to back bathrooms without a double fixture? May 19, 2010
Plumbing Forum, Professional & DIY Advice The elusive "double fixture fitting" Feb 5, 2010
