Derek Morgan Jr
Brand new construction home that we close on this week and need to order a softener.
8 people (6 kids that are home only 60% of the time). Not everyone showers everyday there is a schedule.
Hardness: 269 Mg/l (ppm) from a Lab. I don't believe any iron.
Was thinking 64k grain system with Fleck 5810 valve. Water line coming into home is 1" pex and not to long after it enters the home it splits to 3/4 (before water heater, etc). I was planning on coming off the 1" and then feeding through softener and then into a pelican whole home water filter to remove chlorine and then back to the main line to feed the house (probably going to bypass the external faucets as well depending on how they have it plumbed).
3.5 baths.
The softener is believe would be 13gpm and the pelican filter is either 10gpm or 15gpm depending on which one I buy (1mil vs 600k).
Also thinking 10% crosslink resin but would it be beneficial to spend the $150-$200 for SST60 resin or save my money?
15x17x36 Rect Brine Tank with salt grid and safety float assembly.
Any issues with this setup that you can see?
3.5 baths.
