Double check my plan
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by pghsebring, Mar 30, 2010.
  1. pghsebring
    pghsebring DIY Member
    Oct 23, 2008
    Florida
    I have 3 questions.
    First, do i just use a regular 1.5" elbow in the upper right?
    Second, do i just use a regular 2" elbow in the lower left?
    Third, can i use a 2" santee in the bottom right instead of a 2" wye + 45 (store don't got no combos)?
    Oh - and any other problems you see?
    - I just realized, you may want to know, this is for a double bowl kitchen sink.
    Thank you in advance.
    [​IMG]
  2. Terry
    Aug 17, 2004
    The 2" 90 El below the tee on the left would be a long sweep.
    The 1.5" 90 el on the vent, can be a vent 90 or a med 90
    I normally carry med 90 and long turns, no vent 90'sin the truck.
    They are a fitting that is rarely used.
    Inspectors like to see a 2" cleanout.
    [​IMG]
  4. shacko
    shacko Master Plumber-Gas Fitter
    Jan 22, 2006
    Rosedale, Md
    Agree with Terry about the ell and a c.o. If your sink bowls are two different depths make sure you put your rough-in low enough for the lowest bowl.
  5. pghsebring
    Oct 23, 2008
    Florida
    Thanks guys, now i just need my third question answered -
    Can i use a 2" santee in the bottom right instead of a 2" wye + 45 (store don't got no combos)?
    All of this is sitting in one stud bay BTW - less than 16" wide.
    Thanks again.
  6. Basement_Lurker
    Basement_Lurker One who lurks
    Jun 21, 2007
    I smash things and demand money.
    Victoria, BC
    Yes you could use a santee to make the transition instead of a wye.
    I am curious as to why you are trapping each sink, are you just doing it out of preference or is it code where you are?
  7. pghsebring
    Oct 23, 2008
    Florida
    Preference while i have the wall open. I figure it can't hurt. I'm gonna have two sinks, dishwasher and garbage disposal, this makes it easier later i do believe. One sink into wall, disposal into wall, nice and clean.
    Thanks for the help.
  8. hj
    Lont turn elbow on the left, sanitary tee on the right, and a tapped c.o. tee in place of the vent tee. 1 1/2" tapped tee meets the requirement for a full size opening, vent tee does not. Why go to all that trouble? There are easier ways to do it, and I only make multiple inlets when it will be a triple sink.
Similar Threads: Double check
Plumbing Forum, Professional & DIY Advice Plumbing double check Jul 6, 2016
Plumbing Forum, Professional & DIY Advice Installed Vents. Please Doublecheck My Work. Thanks! May 3, 2016
Plumbing Forum, Professional & DIY Advice Checking my plumbing - single sink to double sink Aug 8, 2014
Plumbing Forum, Professional & DIY Advice double sink vanity rough plumbing -- please check my plan Jul 29, 2014
Plumbing Forum, Professional & DIY Advice Moving toilet - need someone to double check my idea... Feb 2, 2013
