I am installing a reverse osmosis system (50-gal model at www.diyreverseosmosis.com). I cannot spare space near the sink so I have to have it in my laundry room which is approximately 17' away, as the hose lies. All connections are 1/4" OD hose compression fittings. I have public water not a well.
The instructions state that runs longer than 10' from the pressure tank to the faucet require 3/8" OD hose to prevent a pressure drop. As I said above, the distance is 17' and I will add that the tank is 3' higher than the faucet. Does this increase in hose size make sense?
If you agree with increasing the hose size, I am still stuck with 1/4" fittings on both ends. Do these "bottle necks" negate the benefit of the larger hose?
I appreciate anything you can add to help me through this job.
Thank you in advance!
Jax
Jax
