Do I need to increase hose diameter for a longer than "normal" run?
JaxPlanet
Maryland
I am installing a reverse osmosis system (50-gal model at www.diyreverseosmosis.com). I cannot spare space near the sink so I have to have it in my laundry room which is approximately 17' away, as the hose lies. All connections are 1/4" OD hose compression fittings. I have public water not a well.
The instructions state that runs longer than 10' from the pressure tank to the faucet require 3/8" OD hose to prevent a pressure drop. As I said above, the distance is 17' and I will add that the tank is 3' higher than the faucet. Does this increase in hose size make sense?
If you agree with increasing the hose size, I am still stuck with 1/4" fittings on both ends. Do these "bottle necks" negate the benefit of the larger hose?
I appreciate anything you can add to help me through this job.
Thank you in advance!
Jax
JRC3
S.W. Ohio
You want the 3/8 even though it steps back down to 1/4 at the end. It's all about friction loss in the middle. My RO steps up to 3/8 to run from the laundry to the kitchen and I can't imagine the trickle I'd get without the 3/8. Even with my RO booster pump increasing my well pressure well above city pressure.
JaxPlanet
Maryland
Thank you for your quick and clear reply! That is exactly what I needed to know.
I am having difficulty selecting the correct 3/8" to 1/4" coupling and 3/8" hose. My system included 1/4" "food grade piping" so I have that end covered.
What would you recommend?
ditttohead
Water systems designer, R&D
Ontario California
Exactly correct. Frictional losses are key. You could try the 1/4" through and see if it is acceptable but the performance will be greatly increased with the use of 3/8" as much as possible on the run.
