Do I need a vent here?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by JSLayton, Jun 24, 2014.
  1. JSLayton
    JSLayton New Member
    Jun 23, 2014
    Alabama
    The tub will connect to the main line past the vent connection. Does it need a separate connection to vent? The white lines show where the proposed drain will be. The toilet connection is the end of the main line.
  2. jadnashua
    I think you'll find you must vent the tub. The vent must be within a certain distance of the trap whose length varies based on the ID of the drain pipe you're using - you can go further the bigger the pipe before a vent...otherwise, the trap can get siphoned dry.
  4. Terry
    Aug 17, 2004
    The tub will need it's own vent in this case. Within 42" of the p-trap.
    The tub waste is 2" after the vent. The trap arm can be 1.5"
  5. JSLayton
    JSLayton New Member
    Jun 23, 2014
    Alabama
    Thank you Terry
  6. Terry
    Aug 17, 2004
    You're welcome. Don't forget to click a few ads while you're here. :)
  7. hj
    quote; I thought this forum was to help people with plumbing questions? This comment doesn't seem very helpful.
    We are here to help people with DIY plumbing questions, such as how to fix a faucet, NOT to tell people how to install DWV systems which should have a building permit and inspection, which usually requires a licensed contractor. Sometimes the best advice IS to tell you to call a plumber. After all there is more to plumbing than just having a box of fittings, some pipe, and a level.
  8. Tom Sawyer
    Tom Sawyer In the Trades
    Nov 29, 2010
    Maine
    Very true HJ although in truth I belong to about a dozen forums, it was late, I was tired and thought I was replying to someone on another forum that doesn't allow anyone other than licensed plumbers too post, so apologies to the OP and do what Terry said to do.
Similar Threads: need vent
Plumbing Forum, Professional & DIY Advice Need to replace part of cast iron vent stack in my attic bathroom Dec 3, 2016
Plumbing Forum, Professional & DIY Advice Need Help with Basement Bathroom Drain/Vent Nov 15, 2016
Plumbing Forum, Professional & DIY Advice Do drains leading into lift pump need vents and traps Jul 28, 2016
Plumbing Forum, Professional & DIY Advice Need Advice on Vent Stack Jun 22, 2016
Plumbing Forum, Professional & DIY Advice Flip-flop toilet and sink location in small bath - need to mess with vent pipes? May 18, 2016
