DIY dishwasher install to double sink
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by renomama, Jul 10, 2010.
  1. renomama
    renomama New Member
    Jul 10, 2010
    NY
    [​IMG][​IMG]
    My friend says this will work, is he right? I'm afraid I'm going to have backup. If it's not right what will work better?
    Thank you :)
  2. Terry
    Aug 17, 2004
    That is wrong, wrong, wrong.
    Cut the tailpiece on the left and have the p-trap grade downhill to the sink drain.
    The first ruile of plumbing, is that water needs to go downhill.
    [​IMG]
  4. jadnashua
    Are those soap bubbles on the rubber connector, too? It isn't sealed well. As plumbed, the drain line (trap arm) will fill up with food particles and crud, and block up. It has to flow downhill from the output of the trap.
  5. hj
    Actually, there is no good way to connect whichever side gets the dishwasher. I would use two "P" traps on that installation, but the "branch tee" is still going to make that one hard to connect properly.
  6. MASTERPLUMB777
    MASTERPLUMB777 Member
    Aug 6, 2007
    Retired Master Plumber
    Texas
    basically you need to cut the wall open and lower the san tee in the wall ! !
    Drainage water " does " not run uphill you have to get that lower in the wall that is
    all there is to it !
    Once you do that the rest of the sink plumbing will come together the right way ! !
  7. jimbo
    jimbo Plumber
    There are three inviolable cardinal rules of plumbing.
    1st rule: things flow downhill. You have created worse than a deep trap, which is a problem in itself. You have a serious crud catcher.
Similar Threads: dishwasher install
Plumbing Forum, Professional & DIY Advice Installing a Samsung Dishwasher with existing Johnson Tee Nov 22, 2016
Plumbing Forum, Professional & DIY Advice Permanently Install Countertop Dishwasher Jun 1, 2016
Plumbing Forum, Professional & DIY Advice Dishwasher Installation Problems May 18, 2016
Plumbing Forum, Professional & DIY Advice Appliance company thinks my dishwasher install is complicated... Apr 18, 2016
Plumbing Forum, Professional & DIY Advice Can I install a compact front load washer in the place of the dishwasher? Apr 3, 2015
