Did my wife "break" our new toilet??
Discussion in 'Toilet Forum discussions' started by frank1890, Nov 9, 2008.
  1. frank1890
    frank1890 New Member
    Nov 9, 2008
    ok, the other day, there was a water main break down the road/downhill from us. water was out for about six hours. I checked the faucet from time to time, and only had air running thru. at any rate, my wife goes, and uses the toilet, only went pee, lol.(2 month old kohler class 5) she forgets to not flush, and flushes, it all goes down, and I hear air shooting thru the lines, i run to the bathroom, and turn the incoming water valve off under the toilet. No biggie i figure, when the water comes back on I will just turn the valve back on. ok water comes back on, I turn the valve on, a little air hisses thru, then water fills the tank. good i say to myself. now for fun i test flush it, and see that now, when it flushes, not all the water goes down the bowl like it did before. AND there seems to be a shoot back of sorts, like it splashes back up higher than the seat!! (uh oh, thats not good lol) being the class five, i try to flush it holding the handle down to get the maximum flushage. works fine every time. but I bought this to save water. Oh, also, some times(maybe 1 in 5 flushes) it works fine. what happend to this fine unit??? Oh, BTW she also accidentally flushed our 30 year old toilet too and I had to shut that valve off as well. That one is still running fine no problems.Thank you for any help!
    Frank
  2. Terry
    Aug 17, 2004
    The only thing that can really happen in a case like that is a clogged fill valve.
    You may need to clean or repair it.
  4. frank1890
    Nov 9, 2008
    Thanks Terry, while I am handy, I do not know what a fill valve is.. thanks again for the advice!
    Frank
  5. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    The fill valve is that piece in the tank that the float is connected to to shut the water off when the tank is filled. There is probably some debris from the break that has clogged it.
  6. Southern Man
    Southern Man DIY Hillbilly
    Jun 27, 2008
    North Carolina
    The float acts on the fill valve. Follow the mechanical connection to find the valve.
  7. hj
    toilets
    She did absolutely NOTHING to the toilets. That is the way they work when the water is turned off. You can flush them once, but then have to wait until the water is turned on to flush them again. ANY problems you have are because of something else.
  8. frank1890
    Nov 9, 2008
    Thank you guys fo your tips. Actually what appeared to have happend was..... after she flushed, as the air shot back into the bowl, the small plastic rubbery water line "popped" off its placement in the center of the tank.. I replaced it, and all is well.. thanks again!:)
  9. Southern Man
    Jun 27, 2008
    North Carolina
    I see that your toilet has a "bidet" style flush. :)
  10. kingsotall
    kingsotall Plunger/TurdPuncher
    Aug 17, 2008
    Hand copper part cleaned ready to go
    Flagstaff, AZ Sitting on an upside down 5 gallon b
    I do too! Only thing, it takes a great many flushes to get the job done. :(
  11. Southern Man
    Jun 27, 2008
    North Carolina
    Get used to it.
Similar Threads: wife break
Toilet Forum discussions wife says “fix the embarrassing toilet!†before the holidays. Dec 18, 2006
Toilet Forum discussions Vacuum Breaker Flush - Household Use Dec 4, 2009
Toilet Forum discussions Breaking Base or Tank question. Aug 28, 2009
Toilet Forum discussions Caroma Receives Popular Mechanics Product Breakthrough Award Oct 21, 2008
Toilet Forum discussions Toilet Noise after Flush/Sudden Pipe Break Jul 5, 2008
