Andy VH
Well, all is NOT well with the Danco Next Hydrostop flush valve I installed in my Kohler Rochelle update. About a week after the initial installation the toilet started to slightly refill about once an hour indicating and internal leak. I adjusted it thinking the stationary seal was not fully seated, no better. I took it out and reset it per the Danco instructions, no better. Yesterday I installed a brand new flush/overflow tower, and reset the Hydrostop. And it did it again!!
So I drained the tank down below the water level of the Hydrostop valve seal. So any water in the tank is only maintained by the silicone seal of the flush riser tower. And I added blue food color die in the water to see if any leaks into the bowl. So far, an hour later the bowl water is still clear. I'll let it sit for about six hours and if it does not leak into the bowl, I'm calling Danco technical support.
Anyone else have issues with the Danco Next Hydrostop flush valve? Pictures show the blue dyed water, and note the water level is below the flat seal level of the flush valve,
