Cut off too high
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by FranktownTim, Jun 26, 2007.
  1. FranktownTim
    FranktownTim New Member
    Jun 26, 2007
    Franktown,C CO
    My pump starts when the gauge on the pressure tank reads 40lbs. The pump starts and then cuts off at 80lbs. I've read on this and other forums that 70lbs is the maximum recommended. What problems can be encountered with a pressure above 70lbs? Should I adjust the the pressure switch down? If yes, should the cut in pressure be lowered too (like 30/70)?
    I hope this isn't a dumb question.
  2. Rancher
    Rancher Guest
    There are no dumb questions on this forum, only dumb answers. If you have a typical "square" D pressure switch both the range and gap are adustable, to keep the start pressure at 40 and lower the stop pressure, adjust the lower nut that is off center in the switch, I think counterclockwise will lower the gap (I may not be using the correct terms here but I just dreamed them up).
    Rancher
  4. FranktownTim
    Jun 26, 2007
    Franktown,C CO
    Thanks for the advice. Adjusted to 40/60
Similar Threads: high
Pumps and Tanks Well Forum & Blog. Water is life. Well pump pressure gets high wont stop Nov 11, 2016
Pumps and Tanks Well Forum & Blog. Water is life. What is the highest reasonable pressure to expect from 3/4 hydro-glass Oct 10, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Reducing extremely high levels of Iron, TDS and hardness Jul 7, 2016
Pumps and Tanks Well Forum & Blog. Water is life. High Chloride/Sodium/TDS Levels? Jul 31, 2015
Pumps and Tanks Well Forum & Blog. Water is life. Pump kicks on at 40psi but does not move higher May 28, 2015
