chipy
Hi!
I'm in Chicago, and this is a georgian style home with an extension. A few days ago the hub of drain i epoxied broke off (master bath, part of the extension). As you can imagine, it smelled like a sewer here until temporary remediation. Actually, it always kind of smells like a sewer here... s valves dry up all the time.
There is extreme corrosion and i believe it is because of sewer gas and the line being seldom used. It's mostly cheese now at each end of the horizontal pipe. Also, the top hub of the connecting tee (with right side inlet) has cracked. Through the wall, the master bath extension goes straight up.
Had a few quotes from 525 and up to 650; more if they have to dig through the wall to repair the double l style coupling on the left (not likely).
Most want to remove the highlighted red part (photo below), tee included, and leave the complex iron casting above it (what is this called?).
There's a lot of improper work here and i would like to get this right for once, at least part way so that i can finish later.
I have labeled the photo to the best of my ability. Red being what to remove.
What should i do with the tee? Should i simply replace this design with plastic (tee and all), or should i do a wye to the master and another wye on top of it to the kitchen, or should i use some kind of double wye? Any recommendations?
I would prefer ABS. As far as my research takes me, it is a superior material; especially in terms of chemical resistance and health/environment (no chlorine to release in a fire, no BPA to leach into the environment (PVC)). Thoughts?
The photo can be found in this folder (current.jpg): www.googledrive.com/host/0Bze0jIhHLC6lflV4R0FLdlo3Z1o1LWluR044eVZ4SDJjdHhUWXZwX2lTY1RiWU9qamd4U0U
