Copper L vs M
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Climber, Jan 23, 2006.
  1. Climber
    Climber New Member
    Jan 13, 2006
    Columbus, Ohio
    My quest for knowledge continues...
    In the process of completely rerouting and replacing my water lines a question continues to plague my mind (@#&! the voices!) :confused: Should I have used L instead of M? How many thousandths of an inch difference is there between the three schedules of copper pipe? If the water is going to eat through M, does using L or even K make a difference? My water is a municipal source and has a pH of 7.8 and a total chlorine of up to 2 ppm, so the typical problems associated with well water is not an issue. My thoughts tell me proper grounding and the use of dielectric unions when dissimilar metals would make contact are the most important factors to look for. I can't find any suggestions per the IRC or UPC unless it's in regards to above or below ground application.
    Also, my incoming water line is galvanized steel (I wonder how much longer that's going to last if it doesn't choke off my water supply first) does the water meter act as a proper union?
    Speaketh your divine knowledge o' plumbers of renown. :D
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    If you click on the "Replacing Pipes" link on the Terry's home page, your question is addressed.
  4. Climber
    Climber New Member
    Jan 13, 2006
    Columbus, Ohio
  5. Gary Swart
    Sep 1, 2004
    Yakima WA
    :) Sure is! This is a bit too technical for me, I just wanted you to see that Type L is standard for interior household plumbing given the Ph is within defined limits, which yours is.
  6. hj
    copper
    In any given area, "L", or "M" could be the "standard" for above ground inside the house water pipes. Everywhere I have been for the past 55+ years, "M" has been the material of choice for domestic water piping.
  7. toolaholic
    toolaholic General Contractor Carpenter
    Jul 16, 2005
    Repairing and remodeling homes
    Marin Co. Ca.
    i'm originally from the east coast
    type l was always used in my and everyone elses new home.
    only place you'd see M was feeding hydronic base board
Similar Threads: Copper
Plumbing Forum, Professional & DIY Advice Bending 3/8" chromed copper supply pipe to toilet Monday at 8:27 AM
Plumbing Forum, Professional & DIY Advice 3 Inch copper waste pipe cracked and leaking. Feb 13, 2017
Plumbing Forum, Professional & DIY Advice Replacing Copper Water Supply Line with PEX? Feb 2, 2017
Plumbing Forum, Professional & DIY Advice The beginning of a copper repipe Jan 29, 2017
Plumbing Forum, Professional & DIY Advice 3/4" threaded = brass or copper Jan 27, 2017
