Concrete coming tomorrow 3" pipe and flange on the outside
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by joallen001, Jun 27, 2013.
  1. joallen001
    joallen001 New Member
    Oct 24, 2012
    TN
    I have concrete being poured tomorrow and have a 3" pipe that will need a flange. I know they make 3" flanges that go on the inside but I would rather put it on the outside of pipe. What is the best way to wrap the pipe so room is left for the flange to be glued on. I was thinking something like foam pipe insulation and melting it out with a torch after the pour. I am a little afraid the foam may push in to far with the concrete weight. Just trying to save myself from having to chisel it out later. Any suggestions on this? Also is a flange with stainless steel the best to use on a slab pour? I am staying away from the all plastic flanges!
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    You're on the right track with the outside fitting flange, and SS is always preferred over all plastic. Go to a building supply house, even a big box store probably will be OK, and get the foam sleeve that is made for the purpose.
  4. hj
    sleeve
    They make foam sleeves and also wrapped corrugated cardboard ones. You just "pick" them out after the concrete is poured, you DO NOT "melt" them out. Don't do like a homeowner here did years ago. He formed his area and then called for the concrete to be delivered. He told his wife to have them pour it inside his form. A few hours later the concrete company got a call. He said, "You delivered my concrete 4 hours ago and it is still in a big pile. When does it level itself out?"
  5. johnjh2o1
    johnjh2o1 Plumbing Contractor for 49 years
    Aug 9, 2009
    Retired
    Florida
    We use a 4"x 3" 90 with 4" pipe coming through the slab. Then you can get a flange the fits inside the 4" pipe.
    John
  6. leejosepho
    leejosepho DIY scratch-pad engineer
    Nov 23, 2006
    disabled-retired industrial fabricator
    At least they got the slump right, eh?! ;)
  7. Terry
    Aug 17, 2004
    I like doing that too. That way I can cut it flush with the finished floor and glue it inside the pipe.
    Also with a 4", if the plumbing gets bumped I have some leeway that I don't get with 3"
  8. hj
    flange
    quote; glue it inside the pipe. I ALWAYS use a flange that slides OVER the outside of the riser. That way I can cut it off AFTER the flange is against the floor.
  9. DavidTu
    DavidTu Member
    Dec 3, 2009
    Seattle, WA
    Terry, I don't follow... how does 4" provide leeway? It would seem if the pipe is not positioned correctly the 3" inside flange is also not going to sit correctly??
Similar Threads: Concrete coming
Plumbing Forum, Professional & DIY Advice How to bring water into a slab foundation. The concrete is coming Thurs!!! Dec 18, 2012
Plumbing Forum, Professional & DIY Advice Can PVC be encased horizontally in concrete Sep 6, 2016
Plumbing Forum, Professional & DIY Advice Best way to raise steel tub off concrete floor? Aug 28, 2016
Plumbing Forum, Professional & DIY Advice Sewer cleanout (and cover) in concrete Jul 31, 2016
Plumbing Forum, Professional & DIY Advice Hose spigot leak in concrete slab! Jul 18, 2016
