Compression for Black Steel
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by chefwong, May 9, 2012.
  1. chefwong
    chefwong Member
    Jun 14, 2006
    District of Columbia
    Was at our storage facility --- commerical space
    For the sprinkler system, they ran black pipe.
    What I found interesting - it looks like some sort of compression fitting used on all the ends of them to join them.
    Similar compression style fitting that were 90 degree units.
    Anyone care to share the link or name so I can google this.
    Was just curious.
  2. Terry
    Aug 17, 2004
    I used to install Fire Protection years ago. We used a Victaulic system for joining the pipes.
    [​IMG]
    The clamping coupling with rubber seal
    [​IMG]
    A 45 fitting
    We also had a way of putting grooves in steel pipe that the fittings used.
  4. chefwong
    chefwong Member
    Jun 14, 2006
    yeap, those are it. Grooves and all.
    I was thinking about the propress and tooling.....and was wondering why something similar like *above* did not exist for water feed systems..
    Thickness of walls for the groove
  5. Terry
    Aug 17, 2004
    They are also used for water supply inside large buildings, done mainly with copper pipe. The copper can be grooved too. It's like a roller that puts a bend in the copper for the fittings to set in.
  6. chefwong
    chefwong Member
    Jun 14, 2006
    Yeepers. I'm youtubing the system right now......
    http://www.youtube.com/watch?v=HyXeN_rrHjM&feature=related
    NM. For the intended application, I suppose a Propress is more superior when a line is hanging in the middle of the ceiling...all you do is cut, slip fittings and *compress* away without needing something to get that groove on.
    Pretty interesting stuff regardless for me atleast
    [video=youtube_share;HyXeN_rrHjM]http://youtu.be/HyXeN_rrHjM[/video]
Similar Threads: Compression Black
Plumbing Forum, Professional & DIY Advice Can't Find Suitable 1/4" Compression Tee? Mar 16, 2017
Plumbing Forum, Professional & DIY Advice Adaptor problem with toilet 3/8 Compression & 7/8 Ballcock Mar 9, 2017
Plumbing Forum, Professional & DIY Advice Looking for a 90° 1/4" male to 1/4" female compression adapter Mar 6, 2017
Plumbing Forum, Professional & DIY Advice 1/4" Pex to 1/4" compression for Ice Maker Jan 13, 2017
Plumbing Forum, Professional & DIY Advice Supply Line Compression Nov 17, 2016
