Common Venting
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Wally Pfautz, Jan 16, 2006.
  1. Wally Pfautz
    Wally Pfautz New Member
    May 19, 2005
    Hi ,
    I need some advice about venting through a new addition roof. We added a second floor and simple trussed hip roof on top of our existing house and I need to poke whatever vent holes are required through the roof prior to shingling.
    There are like 8 or more vents in various locations on the floorplan, as much as 32 feet apart, and now that there is attic space I wonder if we can combine all those vents into one or two to minimize roof holes.
    I've read that the combined vent area should be larger than the main drain and that I need min 1/4 in per foot slope on any vent. Are there any other restrictions that would disallow combining vents in the attic space?
    Thanks so much,
    Hazel
  2. Terry
    Aug 17, 2004
    Combing vents is ok.
    Where the horizontal is more than 1/3 the vertical, you should go up a pipe size.
    If you have 4" going out, then you will need at least
    4- 2" vents.
    or
    1- 4" vent.
Similar Threads: Common Venting
Plumbing Forum, Professional & DIY Advice Is it truly common to run washer drain pain out the external wall??? Jan 10, 2016
Plumbing Forum, Professional & DIY Advice Uncommon Tub Plug - Need help to remove it Jun 6, 2015
Plumbing Forum, Professional & DIY Advice common water supply diagram for multi level condominiums Jan 14, 2015
Plumbing Forum, Professional & DIY Advice How common is it to punch hole in main line for clean out and leave it? Dec 21, 2012
Plumbing Forum, Professional & DIY Advice Common P trap to stubout alignment issue May 19, 2011
