makethatkerdistick
I currently have six plumbing vent pipes penetrating my roof. When reroofing becomes necessary, I'd like to reduce the number of roof penetrations in order to reduce leak potential and for aesthetic purposes.
Is it possible to combine these into two or even one vent roof termination? My plan was to cut the stacks (a mix of cast iron, galvanized steel and copper pipe) in the attic and then via Fernco add a PVC combiner system to it that I can attach to the underside of the attic rafters.
I assume a minimum slope is required for every run so that condensation doesn't gather? If so, is there a prescribed minimum slope? Also, what diameter pipe should the termination piece have? Is 3 inches enough?
Naturally, I want to keep the vent termination away from my fresh-air intake. However, is there a regulation that stipulates a minimum distance from the separate intake for combustion air for my furnace?
Here are the existing vent stacks and their thicknesses:
kitchen: 1.5 in galvanized steel
laundry: 1.5 in copper
bathroom I: 2 in cast iron
bathroom II: 3 in cast iron & 1.5 in galvanized steel
bathroom III: 2 in cast iron
Thanks for all the information you can provide!
