The white enamel on my old cast iron tub was peeling and flaking so I removed it with citrustrip. Underneath that enamel the cast iron tub is sort of a slate blue/gray. I might eventually try to put on a 2 part epoxy enamel but right now I would like to use the tub as is. However there is some sort of gray/white coating over much of the tub I would like to remove. Where there isn't this coating the tub itself is shiny and I sort of like the color.
I've tried mineral spirits, paint stripper, acetone and 60 grit sandpaper with no luck so far. I imagine this coat was put on originally so the baked on enamel would bond better to the iron.
Any suggestions on how to remove this coating? I was thinking of using muriatic acid in small areas and then neutralizing with baking soda before rinsing down the drain.
