Cleanout Required in Vent Portion of DWV?
Spider
This seems like a stupid question, but do the change in direction rules for cleanouts apply to the dry/vent section of a DWV system? I'm adding a full bath to my basement and will be running a new 2" vent line all the way to the attic where it will tie into the existing DWV stack which exits the roof. I plan on doing a cleanout for the DW piping, but not for the Vent, which will require 2, 45s and 2, 90s to snake through the walls and make it's connection in the attic. Thanks.
Spider
Thanks for the quick answer. Are you referring to the flood level of the basement fixtures or the connection point in the attic?
quote; Are you referring to the flood level of the basement fixtures or the connection point in the attic
ALL fixtures, regardless of which floor they are on.
