Clack Retention Tank Problem
Discussion in 'Water Softener Forum, Questions and Answers' started by asmart82, May 29, 2012.
  1. asmart82
    asmart82 New Member
    Jan 26, 2011
    East Orlando FL
    The inlet port on my retention tank is causing my plastic c-clip to come off when I screw in the pipe connection, thus allowing water to spray back out. Anyone ever have the issue and/or know what might cause it? The pipe connection screws in fine on the outlet side.
  2. Tom Sawyer
    Tom Sawyer In the Trades
    Nov 29, 2010
    Maine
    Does your tank have the by-pass valves or plain adapters? At any rate you may want to try screwing the pipe into the adapter and then install the adapter and c clip. If that don't work then something is f'd up (technical term) and you probably need to replace the inlet adapter assembly. And remember, it's plastic so don't gorilla the fittings in
Similar Threads: Clack Retention
Water Softener Forum, Questions and Answers Clack WS1 brine time Feb 13, 2017
Water Softener Forum, Questions and Answers No Brine Draw Clack WS1 Dec 10, 2016
Water Softener Forum, Questions and Answers Removing Clack Valve Dec 9, 2016
Water Softener Forum, Questions and Answers Clack WS1 - two tank GAC setup ? Sep 11, 2016
Water Softener Forum, Questions and Answers Clack WS1 backwash ? Sep 10, 2016
