Checking Water Level - Sandpoint
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by mistermango, Aug 17, 2009.
  1. mistermango
    mistermango New Member
    Apr 27, 2009
    Hello all. I started a thread a few months back (it's here) and got some great feedback from the community. I'm hoping to expand on that thread where it left off.
    Conditman, suggested in that post that I probably have a sandpoint well. Does anyone know of a way of confirming that a well is, in fact, a sandpoint?
    Also, how is the best way to check water level in a well? The supply line is 1.5" PVC, encased in concrete. I assume I can saw off just below the 90-degree elbow that turns the pipe toward my (broken) pump and access the well that way.
    If I drop, say, a weighted string, will I be able to judge if there's water available? If so, how much should I be looking for to know that the sandpoint well (if that is what I have) is viable?
    Photos of my situation are embedded in the thread linked above.
    Thanks in advance.
  2. valveman
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
    I do not see a check valve so there must be a foot valve at the bottom of the 1.5" pipe down in the well. If you cut the pipe and drop a string, you will only find out how deep it is to the check valve. I don't know what is under that concrete. I guess it could be a point well but, it is PVC pipe and would have to have been washed in. Wouldn't surprise me if the well is 4" pipe with 1.5" drop pipe for the pump, and just concreted instead of using a well seal.
  4. mistermango
    Apr 27, 2009
    Thank you, valveman.
    Does anyone have any advice on how to suss out what's going on under there?
    Speedbump had suggested in my previous thread that I rent a pump and see if the well's viable. Any suggestions on how to do that on the cheap?
    If there is a foot valve on the end of the PVC supply line, is there any way of telling if it's gone bad?
    Thanks.
  5. valveman
    Mar 15, 2006
    Lubbock, Texas
    Dig around the concrete and see what you find.
Similar Threads: Checking Water
Pumps and Tanks Well Forum & Blog. Water is life. checking water level at 520 feet well(drilled to 880 feet) Mar 30, 2014
Pumps and Tanks Well Forum & Blog. Water is life. Airline for checking water level? Dec 12, 2012
Pumps and Tanks Well Forum & Blog. Water is life. Maker's recommendations on checking precharge ? Oct 26, 2015
Pumps and Tanks Well Forum & Blog. Water is life. Checking well depth Jun 18, 2014
Pumps and Tanks Well Forum & Blog. Water is life. Help checking my installation plan for submersible pump (and a question) Jun 7, 2014
