Mckeand13
Engineer
I’ve been shopping around for a new pressure tank (Well-X-Troll WX-202XL) and also looking at the tank tee packages offered by many distributors.
I often see a check valve included in the tee package, which apparently is intended to be used on the “outlet” side of the tee servicing the home.
My current setup does not have a check valve. When I plumb in a new tank, should I use a check valve, and then why should I used a check valve? I can’t see the purpose of it.
Here's one example: http://www.aquascience.net/tank-tee-packages/
Thanks.
Thanks.
