Changing to a flush valve toilet
pcave
British Columbia
I'm trying to cheaply replace a basement bathroom's floor-mounted, wall-outlet toilet, but everywhere I ask tells me it is a special order that will cost upwards of $700 with a 4-6 week lead time. SO, in the interest of saving time and money, I'm considering switching to a commercial toilet with a flush valve (ie. no tank).
My question is: How hard is it to plumb in a flush valve toilet? Do I just have to reroute the water supply from the existing tank shut-off valve to where the flush valve requires it? Or is larger pipe needed?
Second question: There's a jog in the wall behind the toilet (ie. a shelf). Can you usually extend the piece of pipe that goes from the flush valve to the wall? Would that be a problem?
Peter
Jimbo
San Diego, CA
Flushometer valves typically spec a 1" water supply line. It's not that they need any higher pressure than you have available, but they need a very high instantaneous GPM. So, it may not work.
That's a lot more than I've been selling the Gerber floor mounted rear outlet toilet for, model 21-310, $399.00
Or the American Standard Yorkville for $499.00
These models use a Flushmate, and work with a 1/2" water supply.
Takes me a couple of days to get these in the Seattle area.
A commercial flushometer, with the 1" supply would need a new water meter, water service, and repiped 1" line to the toilet.
Not a cheap way to go.
specialist
Ikat
New York
American Standard Flemington?
Terry's report on "best low flush toilet" does not mention the American Standard Flemmington, which is only one of a few options for those of us with back outlet toilets. I've read that it is tricky to install, but nothing about its performance.
The other options I have are Kohler Barrington, which is not comfort height, and Duravit Starck, but I can't find reviews on them and am leery about installing something behind the tile that isn't "proven."
I don't know whether the Gerber rear exit comfort height has the problems being reported elsewhere on this site but that high a failure rate has pretty much put me off than brand.
Suggestions?
Gusherb94
chicago/nw IN
www.youtube.com
An expansion tank could be plumbed in to get that "very high instantaneous GPM" without upsizing the houses water service. Pretty much that would be kinda like making a home made pressure assist toilet.
You could pipe a one inch supply from an expansion tank.
So what looks better, an expansion tank in the room, or an enclosed tank using a Flushmate.
If it's about looks, being more commerical looking, you would need a place to set the expansion tank.
And it would need to be an expansion tank with 1" threads.
