Changing a pressure gauge
Steven Palmisano
Florida
I need to change the Pressure Gauge on my well, can someone tell me how to do this? Is there a place where I can purchase, and what is the best type. Is there a standard size?
Thanks,
Steve
Speedbump
Active Member
Riverview, Fl.
Sure you can do it yourself. In most cases the gauge will be a 2" gauge with a 1/4" male pipe thread. You want to turn off the pump first and let all pressure off the system first. Otherwise you won't need a shower for a while.
Most of the gauges you see on water systems in homes are of the 3 - 5 dollar range. They work for the installer to set things up then fail shortly there after. If you want a good liquid filled gauge you can spend a lot more than 3 - 5 dollars.
bob...
Steven Palmisano
Florida
Speedbump, would I use Taflon tape? I never know when to use the stuff.
I purchased a 2.5 LM Liquid filled gauge 160 psi
thanks
