Caroma toilet water level
Discussion in 'Toilet Forum discussions' started by watergirl, Oct 16, 2005.
  1. watergirl
    watergirl New Member
    Oct 16, 2005
    My Caroma toilet tank is not filling to the mark. I know I have to adjust the float but how do I do that? Thanks
    [​IMG]
    Inside the Caroma Sydney tank
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    Usually the float is a plastic cylinder that has a metal rod through the center that acts as a guide. There is a metal clip on the rod to stop the float when the water reaches the full level. The stop point is adjustable by sliding the clip up or down on the rod. Even if you toilet has some variation on the above, it should be fairly obvious as to what limits the rise of the float. That said, if the water level is fairly close to the mark and the toilet is flushing OK, leave it alone.
  4. Terry
    Aug 17, 2004
    Caroma uses the Fluidmaster.
    If the adjustment can't be made using the clip, you may need to lengthen it.
Similar Threads: Caroma toilet
Toilet Forum discussions 24 Unit Toilet Purchase - Need Some Input (Toto/American Standard/Duravit/Caroma/Stealth) Feb 9, 2017
Toilet Forum discussions Toto Drake II 1 gallon toilet vs Caroma Somerton Smart Nov 19, 2015
Toilet Forum discussions Toilet suggestions - replacing Caroma Apr 10, 2011
Toilet Forum discussions Desperately seeking parts for a Caroma Toilet - need dual flush seal washers Mar 11, 2011
Toilet Forum discussions Rear Outlet Toilets Kohler Barrington or Caroma Sydney Smart Back Outlet Round Front Apr 16, 2010
