Caroma Caravelle vs Toto Drake for water savings?
Discussion in 'Toilet Forum discussions' started by 2Bgreen, Nov 11, 2009.
  1. 2Bgreen
    2Bgreen New Member
    Nov 11, 2009
    Melrose, MA
    After much research and agonizing I'm down to deciding between the Caroma Caravelle 305 Dual Flush 1.6/0.8 Gpf and the Toto Eco Drake CST744E with the single 1.28 Gpf. From what I've read, the smaller water spot on the Caravelle may necessitate a second flush (and brush clean) which will defeat it's water saving purposes. I've also heard that the Drake is very efficient and powerful and one flush will handle anything. My main concern is the water savings. I have two kids and a "clean toilet" fanatical wife. Any help with making this decision would be appreciated.
  2. Terry
    Aug 17, 2004
    They both average out at about 1.28 gallons.
    For cleaning and for the boys, get the CST744EG
    That model has an elongated bowl, a little easier for the boys to hit the bowl.
    Sanagloss, a smooth finish, for less cleaning
    Get the softclose SS114 seat, no more slamming seats.
    Below are a few of the toilets I'm selling.
    TOTO with Sanagloss on the left, Gerber Ultraflush, and Caroma dual flush on the right
    [​IMG]
  4. 2Bgreen
    2Bgreen New Member
    Nov 11, 2009
    Melrose, MA
    Thank you for the quick reply! One more question. Is the Toto Drake easier to install than the Caroma Caravelle?
  5. Terry
    Aug 17, 2004
    Way easier.
    [​IMG]
    TOTO Drake
    For one thing, the tank comes adjusted from the factory.
    Their are also fewer defects, less chance of having to do the job twice.
    The Drake is more compact, so it takes up less space.
    The seat is better quality then the Caroma seat.
    And the Drake doesn't spray droplets of water onto the seat like the Caroma does.
    The Caroma is good if the kids have medical problems with stools that are extreme in size.
    You can pass a potato through these things.
    [​IMG]
    Caroma
  6. Runs with bison
    Runs with bison Member
    Aug 23, 2009
    Midwest
    EcoDrake elongated with sanagloss would probably serve you best based on what you have said. That's the route I recently went. My old Gerbers had a waterspot about the size of the Caroma...and that was not good from a bowl cleanliness standpoint. These Drakes are staying very clean so far. For boys/men peeing in the dark, a large waterspot and elongated bowl is a good thing. ;)
    Other than the small waterspot in the Caroma's I was also concerned about the splashing that some owners had described.
    I'm using the standard height elongated, but if you want some extra flush capacity you might consider the ADA height (900 vs 600 in the MaP tests.)
    I can't say for sure on the water savings of the dual flush vs. single. Some of it depends on the number of females vs. males I suppose. My understanding is that TP use typically requires the full flush, so the ratio of full flushes will be higher for the ladies.
  7. 2Bgreen
    2Bgreen New Member
    Nov 11, 2009
    Melrose, MA
    Finally got The Drake installed. Thanks everyone for the help deciding. The only trouble I ran into was that my old toilet had about 1" of clearance for the flange under the base. The new Eco Drake gives you about 3/8". Since my flange needed that extra space because it was old, cracked and crooked I had to have a plumber come in to replace it. He finished the install for me and things are flowing wonderfully...
    Thanks again.
  8. pottygirl
    pottygirl New Member
    Nov 30, 2009
    Marietta, GA
    Toto vs Caroma
    Hi Terry,
    the Toto uses 1.28 gpf every single flush, the Caroma uses 0.8 gallons for liquid and 1.6 for solid waste, which averages to about 1 gallon per flush (based on the widely used average of 4 liquid/1 solid uses a day).
    Also, Caroma models are also available with elongated bowls, both in regular height (15") or ADA compliant "easy height" of 17" to the rim.
    Best regards,
    Andrea Paulinelli, ecoTransitions Inc.
  9. Terry
    Aug 17, 2004
    The Caroma also uses more space in the bathroom,
    Sprays the seat during a flush
    And the bowl gets dirtier.
    For those reasons, I haven't been selling as many.
    The TOTO Aquia is better in those three areas.
    And I have less returns with the Aquia, so make that four.
    The Aquia is a dual flush toilet.
Similar Threads: Caroma Caravelle
Toilet Forum discussions Caroma Caravelle 270 shut-off valve doesn't Jul 29, 2011
Toilet Forum discussions Caroma Caravelle 270 just installed ... doesn't seem to be flushing well Apr 2, 2011
Toilet Forum discussions Caroma Caravelle Installation concern Aug 11, 2009
Toilet Forum discussions Help! Aquia or Caroma Caravelle Mar 5, 2009
Toilet Forum discussions Caroma Caravelle streaks Nov 30, 2008
