I am not a pro, so I would be thinking of a tape such as silicone self-fusing tape such as
https://www.rustoleum.com/product-c...erformance/specialty-products/Leak-Seal-Tape/ . There are going to be other ways, even solutions suitable for pressure pipe.
The Homewerks Worldwide 1-1/2 in. PVC Slide Repair Coupling could also be used. It is OK for pressure even. Also available in other sizes.
Even cheaper is to use two 1-1/2 in. PVC DWV Repair Couplings and a piece of PVC. The repair coupling does not have the stop in the middle, so you can slide those over the pipes totally before you apply primer and glue. I am a bit concerned that the repair couplings don't have the interference fit of regular PVC couplings. You are not supposed to use that for pressure fittings, but yours is a vent application.
