Can you place a flexible cap over a cleanout
California
I am replacing my 4" clean out flush plug with something that will loosely go over the top instead. Like a flexible cap.
However, I am not sure if a 4" Fernco flexible cap with a hose clamp will just fit over the top as the outside diameter of the end of the clean out has those ridges that creating a larger outer diameter?
Here is a link to a 4" clean out that looks similar to what we have installed and poking out of the ground:
https://www.homedepot.com/p/NIBCO-4...MERCH=REC-_-searchViewed-_-NA-_-205840065-_-N
Here is a link to a 4" cap that I want to place over top, just not sure it will fit?
https://www.homedepot.com/p/Fernco-4-in-Plastic-DWV-Flexible-Cap-PQC-104/100372305?NCNI-5
Ideally I need something that can sit on top and be a bit loose so if there is a back up the cap will be pushed away and the back flow will come out of the clean out. They make $25 devices that screw in but this could work for 4$ too?
Can a 4" flexible cap sit over a 4" clean out? Again check out how thick the outside diameter of the end of the clean out as shown in the link.
Before I buy these just wanted to see if anyone could give me some advise if they have done this?
I am not addressing what is permitted, or even it the concept is a good idea.
The rubber cap you pointed to, as far as I can tell, is made to go over the end of a 4 inch pipe, which is 4.5 inches OD. Your fitting in the yard may be considerably larger.
Breplum
Licensed plumbing contractor
San Francisco Bay Area
We use rubber 4" caps all the time to serve as loose-enough outdoor caps. We remove the hose clamp to make sure some numbskull doesn't come along to tighten the hose clamp.
A 4" cap is designed to go over pipe so won't work w/ your existing fitting.
Just buy the expensive screw in pop off if you want the simplest solution.
California
I might first ask a few questions along the way before doing it the easy way.
4$ caps x 10 clean outs $40
27$ pop offs x 10 clean outs = $270
Easy comes with a price right. Figure I would do a little homework first, see if someone has experience with this scenario.
Thanks
California
Well 54 clean outs at the complex. but they will not be the same sizes so 10 is a nice round number for what I need. Is that helpful or were you just saying "10 clean outs?" like that is a lot for one house, no really knowing this is for a complex. All good. Just looking for help, but happy to clarify anything if it helps.
That's it. However for a complex, there is an an increased chance of children lifting the caps, and dropping stuff in.
