Can you mess up a Unifit install?
Discussion in 'Toilet Forum discussions' started by Mollie, Jul 30, 2013.
  1. Mollie
    Mollie New Member
    Jul 30, 2013
    Chicago
    We live in a Dutch colonial built in 1928. When we moved in, there was an old toilet in the *one and only bathroom* that sat flush with the wall. We bought a Toto Drake and replaced the toilet. It stuck out about 4 inches from the wall - and was an elongated bowl - which made a big difference in our small bath. We recently did a remodel on the bathroom. Ripped it out, re-tiled, all new features, tub, toilet, sink. Some piping was updated to copper, but the placement of the toilet plumbing was not re-done. I purchased a Toto Guinevere for the express purpose of making the toilet flush against the wall again - or as close as possible. Our contractor DID use the 14 in rough in Unifit piece. The toilet is *still* 3.5 inches out from the wall. He has never installed a Unifit before but thinks he did it right.
    I just can't believe our 14in Unifit is sticking out at almost the exact same distance as the previous 12 in rough in Drake? Is it an "idiot proof" install for the Unifit or could my contractor have not done it correctly?
    Frustrated and trying to understand before we insist he take it out and do it over again.
    Appreciate any insight. Thanks!
  2. Terry
    Aug 17, 2004
    It appears he used the standard 12" unifit that came with the Guinervere.
    I would expect the Guinevere to be about 1/4" to 1/2" closer to the wall than the Drake. If you remove the two nuts that hold the bowl down, and lift the bowl out, you will see a standard 12" rough, not the 14"
    [​IMG]
    It should look like the one on the right.
  4. jadnashua
    FWIW, you should first measure what your REAL rough-in is. To do that, you'd need to first lift the toilet, then measure from the wall to the holes in the large, round part of the Unifit adapter. All of the Totos that use the Unifit adapter, come with the 12" one in the box. You have to buy the 14" one as a separate purchase (and throw the 12" one away, unfortunately). If your rough-in is a true 14" (it could be anything!), with the right adapter installed, the toilet would have about 3/4" behind it to the wall. Any deviation from 14" will either add or subtract from that rear clearance. It would have been better to have changed the rough-in to 12" (if possible) when you remodeled...maybe next time.
  5. hj
    Some people can "screw up" an iron ball, but we do not know what he was working with.
  6. Sean Beck
    Sean Beck Plumber
    Jun 14, 2013
    Toronto, Ontario, Canada
    IF your contractor DID use the 14" rough-in unifit adaptor and the toilet is still 3.5" away from the wall, then you will want to use the regular 12" unifit adaptor that comes with the toilet. This should make the gap just 1.5".
  7. Terry
    Aug 17, 2004
    If the wall was not moved, or the rough-in moved, then he used the 12" Unifit that came with the toilet.
    We have installed hundreds of these. He used the 12" rough, and not the 14"
    It's not an adjustable fitting. They come in three different sizes. We sell the 14" Unifit for $59.99
    I guess your contractor saved by not buying one.
    [​IMG]
    [​IMG]
  8. wjcandee
    wjcandee Wise One
    Apr 27, 2012
    New York, NY
    I know it's a little counterintuitive, but in fact you don't quite have it right. The 14" Unifit presumes that the rough-in is 14" from the wall, so it extends 2" further back towards the wall from the flange to push that toilet closer to the wall. (Have a look at the pictures in Terry's post, above; the 14" is on the right.) If you were to put a 12" Unifit in the same space, the distance towards the wall from the flange would be 2" less, so that the toilet would be 2" further from the wall, not 2" closer.
  9. Mollie
    Mollie New Member
    Jul 30, 2013
    Chicago
    Thanks so much for the responses! Ok- I know he did use the 14 in Unifit piece - because I have the 12 in piece in my possession - and saw the empty box that says "14 in" Unifit on it. That was my first burning suspicion - that he really used the wrong size. I myself purchased the toilet with the additional 14 in rough in part. So it looks like my guy did use the right part. It's true that maybe my rough in is 15 inches. I just needed to verify that you can't really botch this install. The toilet works great. It's just puzzling to me why we didn't gain any space. And if only the plumbing was adjusted when the floor was ripped up. But too late.
  10. Sean Beck
    Sean Beck Plumber
    Jun 14, 2013
    Yeah you're right. My bad. Only installed a few of these and each was with the 12". Jesus, i've a degree in Maths, and I couldn't work this stupid equation out!
  11. wjcandee
    wjcandee Wise One
    Apr 27, 2012
    New York, NY
    Maybe you are holding the 14" one in your hands, and the 12" one is under the toilet. Your guy could have been confused as to which was which (in the same way the contributor a few posts above was a little confused for a moment).
    Clearly, something isn't right. If you had an original Drake (CST744S), and the back of the tank was 4" from the wall, that means you have a rough-in greater than 14". The Drake usually has roughly 1-1/8" behind the tank.
    This would put your rough-in 2-7/8 inches greater than 12", or about 14-7/8 inches. The "II" series Totos, and the one you bought, should have .75" behind it. So you reduce the distance between tank and wall by about 3/8" by using the toilet you installed, if you used the 12" Unifit. Use the 14" Unifit, and the back of your toilet should be an additional 2" closer to the wall. So...you would reduce the distance between tank and wall by about 2-3/8" over your Drake. You would then have about 1-5/8" behind your toilet, not 4. (Or, to do the math another way, take the 3/4" that should exist between the back of your toilet and the wall, add the 7/8" that I think your rough-in exceeds 14", and you get -- voila! -- 1-5/8".)
    You should have reduced the distance between tank and wall by 2-3/8". If you didn't, which should be obvious, and you didn't move the wall and you didn't move the flange, then something's up, and I think Terry hit it right on the head many posts ago.
    Also, for what it's worth, a good plumber can "cheat" a toilet a little closer to the wall by the way he mounts it over the flange -- maybe as much as 5/8". If it's possible to do the same with a Unifit...hmmm. If you have a 3" flange, the hole in the center of the Unifit should be about 2-1/8", so if it's mounted (by fudging with the bolts) a little closer to the wall (say 5/8", there is plenty of difference between the two holes such that the hole from the unifit will still discharge satisfactorily into the 3" hole). Terry (and, I think, Jim) could tell you more about this, but it essentially means that if my math is correct, you could make this toilet look like it was mounted on a normal flange.
    (Of course, it could be that you have a 4" flange and the plumber who installed the Drake moved it within the flange such that he reduced the distance between toilet and wall, and then this guy just installed it straight up, sucking back some of the distance previously-gained. Although that wouldn't account for all of it, it's a possible, albeit-remote, explanation.)
    In short, using my Spidey Sense, I'm looking at the fact that you DID gain the more or less 1/2" difference between the Drake and Guinevere specs, but you DIDN'T gain the 2" you should have from using the 14" Unifit. Spidey says the guy used the wrong rough-in.
    PS Did he read the directions?? Terry says that plumbers don't like to read directions, so he has previously commented (one of my favorites), that the list of required tools to install this toilet includes "Reading Glasses".
Similar Threads: mess Unifit
Toilet Forum discussions Afraid contractor will mess up a Toto Unifit install...need advice. Sep 24, 2013
Toilet Forum discussions Buying clearance with 14" unifit and offset flange Aug 8, 2016
Toilet Forum discussions Help - Toto unifit install on tile question Jun 13, 2016
Toilet Forum discussions Any round-bowl Toto toilets w/14" Unifit rough-in? Jun 9, 2016
Toilet Forum discussions Does Toto make a unifit adapter for Aquia? Mar 15, 2016
