Can I use silicone seal on a PVC pipe with a tiny leak?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by RobS, Aug 9, 2014.
  1. RobS
    RobS New Member
    Aug 9, 2014
    photo-3.jpg I have a TINY - like one drop an hour under heavy use - leak in the pipe going from my garbage disposal to the drain. I just replaced my sink and my disposal is relatively new so I am not planning to do any work under there any time soon. Can I use silicone sealant on the outside of the PVC nut to seal it up?
  2. Terry
    Aug 17, 2004
    [​IMG]
    Normally you just make sure the surface is clean and snug it back up again. I have never used goo on those joints.
    RobS likes this.
    RobS likes this.
  4. DonL
    DonL Jack of all trades Master of one
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    It looks like it may be at a slight angle, Maybe that is why it is not sealing.
  5. RobS
    RobS New Member
    Aug 9, 2014
    Thanks!!! You gave me the confidence to turn it just a bit more. I just filled both sides of the sink 4 times and let them drain -no leak!
Similar Threads: silicone seal
Plumbing Forum, Professional & DIY Advice PVC cement - compatible w/ silicone sealant? Sep 6, 2016
Plumbing Forum, Professional & DIY Advice Silicone or Putty to seal drain to vessel? Dec 17, 2015
Plumbing Forum, Professional & DIY Advice Caulk: Silicone,Polyseamseal, Hercules or Other? Jul 23, 2011
Plumbing Forum, Professional & DIY Advice use of 100% silicone sealant Nov 5, 2006
Plumbing Forum, Professional & DIY Advice Faucet install - gasket on drain piece instead of putty/silicone? Mar 10, 2017
