Can I remove glue and primer from pvc?
r_ventura_23
NJ
I cut a piece of 1 1/2" pvc right at an elbow and I want to put a new fitting on. However, there is some residual primer and glue on the pipe. I can't really cut anymore off due to it's proximity to a beam. Is there a way I can remove this glue and primer and put on a new fitting?
You can scrape off the glue and primer, and then redo the joint. Prime, then glue. I think you will be fine. :)
If you cut the pipe RIGHT at the elbow, you'll need a special tool to ream out the pipe from the existing fitting OR, cut the elbow off, and start with the pipe from the other side with all new. If you do still have a stub of pipe coming from the fitting, as Terry said, scrape off the excess cement and you should be able to install a coupler to go to another piece of pipe and go where you want to with it.
Don't try to remove the old primer. All you are seeing of the primer is the dye. The old primer is already gone.
